So a summary:
( Harkens back to the old Cad/Cam days when I was in that world as a Product Manager
The Filters that will effect the play back of a video on YouTube:
1) My Camera and the "format" it's capable of creating. In my case with the s23
a) High Definition 30fps & 60fps
b) "Ultra: High Definition & 30fps & 60fps
c) 8mm or 4k
2) Video Editors ability to "map" the input file accurately in it's internal "cyber space" working format
3) VERY Important , the Video Editor's ability to create output files close to or the same as the input file with minimum distotion.
4) YouTube or Rumble's ability to first "map" the file and then produce a graphics out put with minimal distortions.
a) YouTube has the ability to "process" to different levels and also play back to match. REALLY cool, from 720p to 4K
5) The graphics card or device on the "viewing" computer, laptop, or phones ability to display the results be it YouTube or From Editor
a) Internet speed plays a BIG role on the YouTube or Rumble play back
b) A high performance graphics card is essential on my computer/lap top to get smooth and crisp play backs from any input from file to YouTube
SO the quest begins ( actually already started ) to find the right "blend" of settings to allow a good video in MY environment & computer as I'm assuming mine is "typical". My Samsung s23 Ultra actually is WAY better than my Lap Top which is a Dell with an older / early Core i7 Processor and an older iVidia graphics card. I have to force my display programs & editors to use that card as the "default" graphics is the onboard the CPU intel graphics. It sucks but If I can make a video play pretty well on it, it will be good enough anywhere.
SO the three camera settings that make the BEST video on the s23 Ultra are hd 60fps, which is "nice" and smooth, uhd 60fps which is spectacular on the s23, and 8mm which also is grat, just with a small screen it doesn't look better than uhd 60fps and it doesn't have the zoom capabilities either at that video setting. I've settled on hd 60fps for now.
A few video editors work, but the one feature that they MUST possess is the ability to input the higher resolution files, and some DON'T; and just as importantly the ability to out put at least at the same level of definition & frame rate as the input. DaVinci Resolve does, Openshot, and Lightworks ( paid app ) all do. I'm using Openshot for a bit to see if it's adequate for my hd and uhd 60fps files both input and output.
My Computer.....man I want to upgrade! But if I do that, what I see with the "Raw" camera output isn't what I can get thru ALL the "stacked" filters & therefor "Tolerance" stack from camera to YouTube and back to Computer
SO same old computer for me as we try "settings" to get the BEST quality video thru put from camera to Play back off YouTube. Rumble doesn't yet have the same "playback" options for the higher quality videos.
