That wig-wag has been in Pullman at that exact same spot for a long long time. If there was anything incorrect/out-of-sorts about its placement, i'm sure it would have been picked up on by the FRA/DOT/etc. ages ago.
That wig-wag has been in Pullman at that exact same spot for a long long time. If there was anything really incorrect/out-of-sorts about it, i'm sure something would have been done with it ages ago.
Not having served any time in the engineering department, I don't know the answer to your question. I went to grad school in Pullman and i'm very familiar with this wig-wag and having served time with UP in the PNW, i'm familiar with the FRA & DOT inspectors in WA State. While it may not be according to Hoyle by today's crossing standards, it's been wig-wagging to its heart's content on Kamiaken Street for at least 50 years without drawing the ire of any FRA or DOT types. In any case, it will most likely be a moot point as the line between Pullman and the bridge that burned up near Colfax in 2006 is most likely going to be pulled up in the near future.
If just one signal, what is the most equitable placement of it?
(After seeing a single wigwag signal in two separate locations, I realized whathis placement was.)
No "standard" of which I know.
Driving on a street I saw my first wigwag signal on my left but on MY side of the track.
I suspected the strange placement to be a way of making it morevenlyisible to both directions of traffic.
Saw another single wigwag signal on my right but on the other side of the track.
Same placement scheme.
Bad Wigwag, bad Wigwag.
So is the one in Pullman, Washington, pictured in my link above.
Guessomeone did not read the installation manual withe Magnetic Flagman.
I believe the single wigwag signal I discovered in Riverside, California was on the left. Even though the track was removed, and what it guarded was cut-off and isolated, it wastill active!
I got itoperate late one night.
Squeaked for the entire duration of it's one-minute operation!
Saw an automobile up the road, so I removed the shunt.
