brad_in_omaha
South Council Bluffs
The Iowa Department of Transportation is working to relocate a railroad line as part of a plan to widen Interstate80/Interstate29 from 6 to 12 lanes.
Red X - Track removed
Green - BNSF
Yellow - UP
Pink - IAIS
Blue - Abandoned Wabash (only on one map)
1. This first images shows the track I think they will remove.
2. This is the "Simple" replacement for that track that Joe A, another local railfan, came up with.
3. Here is another Simple alternative that Railfan Rails Came Up with.
However it sounds like they also want to re-route the UP away from the school so here is another alternative that I sketched up.
4. You can see the school on the right, here I have the WYE Joe described and both the BNSF and UP have their own lines that follow the creek.
5. The lines follow each other until they hit Interstate 29 and split. UP would continue south under 29 and the BNSF would wrap around the outside.
6. The BNSF would follow I29 and tie in to the existing BNSF. The UP would cross the BNSF on a new diamond and tie in to their existing power plant lead
Thoughts?
Green - BNSF
Yellow - UP
Pink - IAIS
Thoughts?
