Shims under tieplates?
trainstuffguy
Canadian Member
Took this some years ago on the CP Havelock sub east of Toronto. for those that know the line this is about a mile east of Dranoel. Its a branch line that has a 15MPH on it Came across these shims under the rails near the top of a long grade. So why the strange shims? do they do this temporarily till a tamper can be brought out?
edit. Its hard to see in the picture but the track in the shimmed area seems higher than the rest so I dont think it was to fix a dip in the tracks. if anything it created a bit of a hump.
LoganTrackdog
When you try to raise track in the winter, the ties are froze down. So you add woo shims as a temp fix. Then when the ground thaws and dries up, remove shims and raise and tamp ties. Maybe they ain't been back around yet!
