Guest
Hello,
I'm doing some research for a story I'm writing which revolves around a train as the setting. The story is fantasy but I'd still like to ground elements in reality enough to make them believable. Since I know almost nothing about trains, and you do, I was hoping to pick your brains a bit on the topic. I chose this section of the forum because most of my current questions have to do with rail lines for the most part.
In trying to research the topic I did not find any references to trains that used more than 2 support rails (there are of course subways that have a third rail for power). Is there any fundamental reason for this or is it more a matter of economics (with additional rails increasing the cost per mile of a line)?
For the story I'm looking at having rather huge train cars, probably on the order of 20 feet wide. I was imagining these running on 4 rails with 6 foot gaps so the overall gauge between the outermost would be 18 feet. The point of the 4 rails would be to spread the weight a bit more and potentially to prevent derailment if one rail was damaged in a localized area.
Because of the size of the cars I'm imagining them mounted on several (probably 4) articulated trucks to allow for a bit better turning. In addition since I imagine that having a single engine pull many of these enormous cars would put unacceptable stresses on the couplings, each car has a small engine to help with the load in addition to the big engine at front (and possibly a smaller engine behind).
Does that explanation sound at all plausible or are you currently in facepalm mode?
